Cytat[18:24:56]
[18:24:56] Finished Work Unit:
[18:24:56] - Reading up to 585764 from "work/wudata_01.arc": Read 585764
[18:24:56] - Reading up to 217004 from "work/wudata_01.xtc": Read 217004
[18:24:56] goefile size: 0
[18:24:56] logfile size: 95457
[18:24:56] Leaving Run
[18:25:00] - Writing 911029 bytes of core data to disk...
[18:25:00] ... Done.
[18:25:00] - Shutting down core
[18:25:00]
[18:25:00] Folding@home Core Shutdown: FINISHED_UNIT
[18:25:04] CoreStatus = 64 (100)
[18:25:04] Sending work to server
[18:25:04] + Attempting to send results
[18:25:04] - Presenting message box asking to network.
[18:27:19] + Results successfully sent
[18:27:19] Thank you for your contribution to Folding@Home.
[18:27:19] + Starting local stats count at 1
[18:27:23] - Preparing to get new work unit...
[18:27:23] + Attempting to get work packet
[18:27:23] - Connecting to assignment server
[18:27:27] - Successful: assigned to (171.64.122.133).
[18:27:27] + News From Folding@Home: Welcome to Folding@Home
[18:27:27] Loaded queue successfully.
[18:27:33] + Could not connect to Work Server
[18:27:33] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[18:27:50] + Attempting to get work packet
[18:27:50] - Connecting to assignment server
[18:27:53] - Successful: assigned to (171.64.122.133).
[18:27:53] + News From Folding@Home: Welcome to Folding@Home
[18:27:54] Loaded queue successfully.
Cytat--- Opening Log file [January 20 17:53:15]
# Windows Graphical Edition ###################################################
Folding@Home Client Version 5.03
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[17:53:15] - Ask before connecting: No
[17:53:15] - User name: BalROCK (Team 91739)
[17:53:15] - User ID: 26FF3E1A5D2EF883
[17:53:15] - Machine ID: 1
[17:53:15]
[17:53:15] Loaded queue successfully.
[17:53:15] Initialization complete
[17:53:15] + Benchmarking ...
[17:53:19]
[17:53:19] + Processing work unit
[17:53:23] Core required: FahCore_80.exe
[17:53:23] Core found.
[17:53:23] Working on Unit 02 [January 20 17:53:23]
[17:53:23] + Working ...
[17:53:26]
[17:53:26] *------------------------------*
[17:53:26] Folding@Home Gromacs SREM Core
[17:53:26] Version 1.02 (Dec 15, 2006)
[17:53:26]
[17:53:26] Preparing to commence simulation
[17:53:26] - Looking at optimizations...
[17:53:26] - Files status OK
[17:53:27] - Expanded 429570 -> 1961605 (decompressed 456.6 percent)
[17:53:27]
[17:53:27] Project: 2966 (Run 63, Clone 6, Gen 17)
[17:53:27]
[17:53:27] Assembly optimizations on if available.
[17:53:27] Entering M.D.
[17:53:47] (Starting from checkpoint)
[17:53:47] Protein: p2966_BBA5_N_Amb99p
[17:53:47]
[17:53:47] Writing local files
[17:53:47] Completed 203679 out of 1500000 steps (14)
[17:53:47] Extra SSE boost OK.
[17:59:32] Writing local files
[17:59:32] Completed 210000 out of 1500000 steps (14)
GX10, D-Xenon 18-55, Tamron 70-300 LD Di, Raynox 250, 135/2.8, 360FGZ
Znaczy, że wysłał. Nie ma jasności do jakiego serwera. Słuchaj wklej jeszcze raz tą cząsteczkę (z tego fashlog_prev) od samego początku (linia wywołania, numer projektu, IP serwera itd) i samo zakończenie - czyli wklej, wycinając po drodze etapy obliczeń, wystarczy jak będzie 1% 2% i 99% 100%.Wajcha napisał/a:[18:27:19] + Results successfully sent
Ż jest P... p.
--- Opening Log file [January 17 15:35:13]
[15:35:23] Opening http://vspx27.stanford.ed...eamnum=91739...
[15:35:46] - Ask before connecting: Yes
[15:35:46] - User name: BalROCK (Team 91739)
[15:35:46] - User ID not found locally
[15:35:46] + Requesting User ID from server
[15:35:46] - Presenting message box asking to network.
[15:35:49] - Machine ID: 1
[15:35:49]
[15:35:49] Work directory not found. Creating...
[15:35:49] Could not open work queue, generating new queue...
[15:35:49] Initialization complete
[15:35:49] + Benchmarking ...
[15:35:53] - Preparing to get new work unit...
[15:35:53] + Attempting to get work packet
[15:35:53] - Connecting to assignment server
[15:35:54] - Successful: assigned to (171.64.122.139).
[15:35:54] + News From Folding@Home: Welcome to Folding@Home
[15:35:54] Loaded queue successfully.
[15:36:23] + Connections closed: You may now disconnect
[15:36:23]
[15:36:23] + Processing work unit
[15:36:23] Core required: FahCore_79.exe
[15:36:23] Core not found.
[15:36:23] - Core is not present or corrupted.
[15:36:23] - Attempting to download new core...
[15:36:23] + Downloading new core: FahCore_79.exe
[15:36:23] - Presenting message box asking to network.
Cytat[15:36:34] Verifying core Core_79.fah...
[15:36:34] Signature is VALID
[15:36:34]
[15:36:34] Trying to unzip core FahCore_79.exe
[15:36:35] Decompressed FahCore_79.exe (2334720 bytes) successfully
[15:36:35] + Core successfully engaged
[15:36:40]
[15:36:40] + Processing work unit
[15:36:40] Core required: FahCore_79.exe
[15:36:40] Core found.
[15:36:40] Working on Unit 01 [January 17 15:36:40]
[15:36:40] + Working ...
[15:36:40]
[15:36:40] *------------------------------*
[15:36:40] Folding@Home Double Gromacs Core
[15:36:40] Version 1.91 (April 11, 2006)
[15:36:40]
[15:36:40] Preparing to commence simulation
[15:36:40] - Looking at optimizations...
[15:36:40] - Created dyn
[15:36:40] - Files status OK
[15:36:41] - Expanded 641034 -> 2256181 (decompressed 351.9 percent)
[15:36:41] - Starting from initial work packet
[15:36:41]
[15:36:41] Project: 2583 (Run 65, Clone 39, Gen 1)
[15:36:41]
[15:36:41] Assembly optimizations on if available.
[15:36:41] Entering M.D.
[15:36:47] Protein: p2583_BBA5_expl
[15:36:47]
[15:36:47] Writing local files
[15:38:51] Extra SSE2 boost OK.
[15:38:52] Writing local files
[15:38:52] Completed 0 out of 200000 steps (0)
[15:50:36] Writing local files
[15:50:36] Completed 2000 out of 200000 steps (1)
[16:02:22] Writing local files
[16:02:22] Completed 4000 out of 200000 steps (2)
[16:05:56] Opening C:\Program Files\Folding@Home\MyFolding.html...
[16:08:16] CoreStatus = 62 (98)
[16:08:16] + Restarting core (settings changed)
[16:08:16]
[16:08:16] + Processing work unit
[16:08:16] Core required: FahCore_79.exe
[16:08:16] Core found.
[16:08:16] Working on Unit 01 [January 17 16:08:16]
[16:08:16] + Working ...
[16:08:16]
[16:08:16] *------------------------------*
[16:08:16] Folding@Home Double Gromacs Core
[16:08:16] Version 1.91 (April 11, 2006)
[16:08:16]
[16:08:16] Preparing to commence simulation
[16:08:16] - Ensuring status. Please wait.
[16:08:33] - Looking at optimizations...
[16:08:33] - Not checking prior termination.
[16:08:34] - Expanded 641034 -> 2256181 (decompressed 351.9 percent)
[16:08:34]
[16:08:34] Project: 2583 (Run 65, Clone 39, Gen 1)
[16:08:34]
[16:08:34] Assembly optimizations on if available.
[16:08:34] Entering M.D.
[16:08:42] CoreStatus = 62 (98)
[16:08:42] + Restarting core (settings changed)
[16:08:42]
[16:08:42] + Processing work unit
[16:08:42] Core required: FahCore_79.exe
[16:08:42] Core found.
[16:08:42] Working on Unit 01 [January 17 16:08:42]
[16:08:42] + Working ...
[16:08:43]
[16:08:43] *------------------------------*
[16:08:43] Folding@Home Double Gromacs Core
[16:08:43] Version 1.91 (April 11, 2006)
[16:08:43]
[16:08:43] Preparing to commence simulation
[16:08:43] - Ensuring status. Please wait.
[16:09:00] - Looking at optimizations...
[16:09:00] - Not checking prior termination.
[16:09:00] - Expanded 641034 -> 2256181 (decompressed 351.9 percent)
[16:09:00]
[16:09:00] Project: 2583 (Run 65, Clone 39, Gen 1)
[16:09:00]
[16:09:01] Assembly optimizations on if available.
[16:09:01] Entering M.D.
[16:09:22] (Starting from checkpoint)
[16:09:22] Protein: p2583_BBA5_expl
[16:09:22]
[16:09:22] Writing local files
[16:10:02] Opening http://vspx27.stanford.ed...eamnum=91739...
[16:10:15] CoreStatus = 62 (98)
[16:10:15] + Restarting core (settings changed)
[16:10:15]
[16:10:15] + Processing work unit
[16:10:15] Core required: FahCore_79.exe
[16:10:15] Core found.
[16:10:15] Working on Unit 01 [January 17 16:10:15]
[16:10:15] + Working ...
[16:10:15]
[16:10:15] *------------------------------*
[16:10:15] Folding@Home Double Gromacs Core
[16:10:15] Version 1.91 (April 11, 2006)
[16:10:15]
[16:10:15] Preparing to commence simulation
[16:10:15] - Ensuring status. Please wait.
[16:10:32] - Looking at optimizations...
[16:10:32] - Not checking prior termination.
[16:10:32] - Expanded 641034 -> 2256181 (decompressed 351.9 percent)
[16:10:32]
[16:10:32] Project: 2583 (Run 65, Clone 39, Gen 1)
[16:10:32]
[16:10:32] Assembly optimizations on if available.
[16:10:32] Entering M.D.
[16:10:52] (Starting from checkpoint)
[16:10:52] Protein: p2583_BBA5_expl
[16:10:52]
[16:10:52] Writing local files
[16:11:17] CoreStatus = 62 (98)
[16:11:17] + Restarting core (settings changed)
[16:11:17]
[16:11:17] + Processing work unit
[16:11:17] Core required: FahCore_79.exe
[16:11:17] Core found.
[16:11:17] Working on Unit 01 [January 17 16:11:17]
[16:11:17] + Working ...
[16:11:17]
[16:11:17] *------------------------------*
[16:11:17] Folding@Home Double Gromacs Core
[16:11:17] Version 1.91 (April 11, 2006)
[16:11:17]
[16:11:17] Preparing to commence simulation
[16:11:17] - Ensuring status. Please wait.
[16:11:34] - Looking at optimizations...
[16:11:34] - Not checking prior termination.
[16:11:35] - Expanded 641034 -> 2256181 (decompressed 351.9 percent)
[16:11:35]
[16:11:35] Project: 2583 (Run 65, Clone 39, Gen 1)
[16:11:35]
[16:11:35] Assembly optimizations on if available.
[16:11:35] Entering M.D.
[16:11:47] CoreStatus = 62 (98)
[16:11:47] + Restarting core (settings changed)
[16:11:47]
[16:11:47] + Processing work unit
[16:11:47] Core required: FahCore_79.exe
[16:11:47] Core found.
[16:11:47] Working on Unit 01 [January 17 16:11:47]
[16:11:47] + Working ...
[16:11:47]
[16:11:47] *------------------------------*
[16:11:47] Folding@Home Double Gromacs Core
[16:11:47] Version 1.91 (April 11, 2006)
[16:11:47]
[16:11:47] Preparing to commence simulation
[16:11:47] - Ensuring status. Please wait.
[16:12:04] - Looking at optimizations...
[16:12:04] - Not checking prior termination.
[16:12:05] - Expanded 641034 -> 2256181 (decompressed 351.9 percent)
[16:12:05]
[16:12:05] Project: 2583 (Run 65, Clone 39, Gen 1)
[16:12:05]
[16:12:05] Assembly optimizations on if available.
[16:12:05] Entering M.D.
[16:12:25] (Starting from checkpoint)
[16:12:25] Protein: p2583_BBA5_expl
[16:12:25]
[16:12:25] Writing local files
[16:14:28] Completed 4000 out of 200000 steps (2)
Cytat[18:12:07] Writing local files
[18:12:07] Completed 198000 out of 200000 steps (99)
[18:23:56] Writing local files
[18:23:56] Completed 200000 out of 200000 steps (100)
[18:23:56] Writing final coordinates.
[18:23:56] Past main M.D. loop
[18:24:56]
[18:25:00]
Cytat[15:35:46] - User name: BalROCK (Team 91739)
Ż jest P... p.
Ż jest P... p.
Ż jest P... p.
Pozdrawiam,
Piotrek
6x7, 1/2.33"
Ż jest P... p.
zorzyk napisał/a:teamu Default też nie dogonimy, ale za to zostawiamy w polu 98.000 innych zespołów
Ż jest P... p.
K1|FA 50mm f/1.4|DA 35 mm f/2.4|Sigma 20 mm f/1.8 EX DG
Pozdrawiam,
Piotrek
6x7, 1/2.33"
Ż jest P... p.
Ż jest P... p.
