PK napisał/a:
Zachęcony pozytywnymi opiniami kupiłem Logitecha marbla- od razu daje się zauważyć, że ten ich "scroll" to ściema. Samo ustrojstwo chodzi całkiem... ciekawe. Dam mu 2 tygodnie a jak się okaże, że to nie moja bajka, to poleci na "giełdę" :evilsmile: .
To?
Ja do scrollowania używam skryptu w AutoHotKey:
;; Emulate_Scrolling_Middle_Button.ahk
;; Author: Erik Elmore <erik@ironsavior.net>
;; Version: 1.1 (Aug 16, 2005)
;; Enables you to use any key with cursor movement
;; to emulate a scrolling middle button.  While
;; the TriggerKey is held down, you may move the
;; mouse cursor up and down to send scroll wheel
;; events.  If the cursor does not move by the
;; time the TriggerKey is released, then a middle
;; button click is generated.  I wrote this for my
;; 4-button Logitech Marble Mouse (trackball),
;; which has no middle button or scroll wheel.
;; Configuration
;#NoTrayIcon
;; Higher numbers mean less sensitivity
esmb_Threshold = 15
;; This key/Button activates scrolling
esmb_TriggerKey = XButton1
;;esmb_TriggerKey = LButton
;; End of configuration
#Persistent
CoordMode, Mouse, Screen
Hotkey, %esmb_TriggerKey%, esmb_TriggerKeyDown
HotKey, %esmb_TriggerKey% Up, esmb_TriggerKeyUp
esmb_KeyDown = n
SetTimer, esmb_CheckForScrollEventAndExecute, 10
return
esmb_TriggerKeyDown:
  esmb_Moved = n
  esmb_FirstIteration = y
  esmb_KeyDown = y
  MouseGetPos, esmb_OrigX, esmb_OrigY
  esmb_AccumulatedDistance = 0
return
esmb_TriggerKeyUp:
  esmb_KeyDown = n
  ;; Send a middle-click if we did not scroll
  if esmb_Moved = n
    MouseClick, Middle
return
esmb_CheckForScrollEventAndExecute:
  if esmb_KeyDown = n
    return
  MouseGetPos,, esmb_NewY
  esmb_Distance := esmb_NewY - esmb_OrigY
  if esmb_Distance
    esmb_Moved = y
  esmb_AccumulatedDistance := (esmb_AccumulatedDistance + esmb_Distance)
  esmb_Ticks := (esmb_AccumulatedDistance // esmb_Threshold) ; floor divide
  esmb_AccumulatedDistance := (esmb_AccumulatedDistance - (esmb_Ticks * esmb_Threshold))
  esmb_WheelDirection := "WheelDown"
  if (esmb_Ticks < 0) {
    esmb_WheelDirection := "WheelUp"
    esmb_Ticks := (-1 * esmb_Ticks)
  ;; Do not send clicks on the first iteration
  if esmb_FirstIteration = y
    esmb_FirstIteration = n
  else {
    Loop % esmb_Ticks {
      MouseClick, %esmb_WheelDirection%
  MouseMove,esmb_OrigX,esmb_OrigY,0
return
I pod małym lewym przyciskiem mam scroll/przycisk środkowy. Czyli jest to najczęściej używany przeze mnie przycisk za zastosowaniach internetowych o-)
Kiedy nim kliknę to otwieram/zamykam zakładki w przeglądarce. Kiedy go trzymam i kręcę kulką to scrolluję.
PK  Dołączył: 24 Maj 2008
Wywaliłem soft od producenta, zainstalowałem jak podałeś i chodzi. Chyba jednak ta larwa kosmity trochę dłużej zostanie.
Dzięki :-B
Cieszę się, że podpasowało :-B
Sprawdziłem i wychodzi, że ja tego używam w pracy gdzieś od drugiej połowy 2016r. Zleciało o-)
Ale szczerze trzeba przyznać, że do precyzyjniejszych/szybszych zadań i tak mam na stałe podpiętą myszkę. Do tematów biurowo-internetowych tylko trackballa używam.
Jednak np do rysowania 2d/3d jest trochę za mało precyzyjny (przynajmniej ten konkretny). A właściwie to nie dałem rady dojść do sensownego kompromisu precyzja-szybkość.
