motaba_virus  Dołączył: 16 Mar 2008
Revueflex SC2 czy ktos zna?
Czy ktos ma jakies informacje na temat korpusu Revueflex SC2?
Warto nim sobie glowe zawracac? Google milcza na temat tego aparatu, a znajac to forum to ktos ma/mial/widzial to body i moze cos o nim powiedziec ;-)
ile mozna za nie dac zeby nie przeplacic?
bede wdzieczny za kazde info
jest to Chinon CM-4
[ Dodano: 2008-11-13, 09:09 ]
Specifications
Film Format : 24mm x 36mm
Type: :TTL, LED type light measuring system.
Lens mount :Chinon Universal Bayonet Mount.(K-mount)
Shutter : Vertically moving Seiko MFC focal plane shutter. Shutter speeds from 1sec. to 1/1000 sec. "B" and "X" /1/90 sec.).
Synchronization : X type contact for electronic flash at "B" and "X" (1/60sec.) and 4sec. Hot shoe.
Exposure meter: TTL, Center weighted full aperture system employing one silicon blue photo cell, 3 steps exposure indicator with 3 LEDs.
Meter ON/OFF Switch: Meter switch is activated when shutter release button is pressed, meter remains on for several seconds after finger is lifted off release button.
Exposure range: EV+2 (F/1.9, 1 sec.) to EV+18 (F/16, 1/1000 sec.) - ASA 100 F/1.9 lens.
ASA Range: 25-1600 (DIN 15-33) with safety lock.
Manual exposure : Manual electronic shutter: stepped speed from 1 to1/1000 sec.
Mirror: Large, Quick return, shockless system.
Viewfinder: Fixed eye-level pentaprism, central split image with microprism collar and ground glass.
Viewfinder Magnification: 0.87 x ((id 50 mm, 00).
Viewfinder Visibility: 92%.
Film Advance: Single stroke in an arc of 130° with 25° stand off.
Film Counter: Automatically indicates number of exposures and resets to " S " when camera back is opened.
Film Rewind: Folding crank type
Self-Timer: Built-in.
Power Source: Two 1.5V Alkaline batteries (LR44, A76) or two 1.5V silver oxide batteries (SR44)
Battery Test: Built-in with LED indicator.
Dimensions: 135.5 (W) x 86.0 (H) x 50.5 (D) mm.
Weight; 455 grams (16.05 oz)
Eldred  Dołączył: 16 Paź 2007
opiszon napisał/a:
najs ;-)
opiszon, dzieki masz u mnie :-B :-)
skad wiedziales ze to ten chinon?
Cypis aka Piotr  Dołączył: 16 Cze 2008
motaba_virus,
http://www.everystockphot...?imageId=686358
tag alt:
"[RevueFlex SC2 a.k.a Chinon CM-4 /Pentacon (Zeiss) auto 2.8/135 MC [M42] Fuji Sensia 100] Freiburg City" :>
Cypis aka Piotr, dokładnie
ale ja zrobiłem tak
ze strony m42.republika.pl wiadomo wszem i wobec, że niektóre revue to chinony (szczególnie modele SC1 i SC3), więc zadałem googlowi zapytanie
revueflex sc2 chinon, i zwróciło mi takie wyniki jak podał Cypis aka Piotr, :-)
[ Dodano: 2008-11-13, 14:33 ]
a potem wystarczyło na google grafika porównać zdjęcia chinona i revue, żeby być pewnym
opiszon , motaba_virus, macie może konto na http://www.camerapedia.org/wiki/ ?
Przydałoby się tam to info dodać.
ja nie posiadam
niestety ja tez nie :-|
