takpoprostu  Dołączył: 10 Kwi 2008
Vivitar 200mm f/3.5
Wie ktoś może czy ten obiektyw Vivitar 200mm f/3.5 wychodził na bagnet pentaxa, a jeżeli tak gdzie można takie cuś zakupić ?
piotr_w  Dołączył: 14 Lis 2006
AFAIR był w wersji P.
Poluj lepiej na Vivitara 200/3.0 :-)
200/3,5 wystarczająco mnie urzekł ;-)
piotr_w napisał/a:
Piotr, możesz linka do jakichś szerszych informacji o tym czymś?
fotonyf napisał/a:
Z linkami gorzej, sporo mam w głowie, sporo w katalogach, niżej to co miałem na ten temat na hdd:
With the D70, I greatly prefer fast lenses, simply because they are so much easier to focus. The 35mm f/2 ZF Distagon is a winner (47mm equivalent), and the 135mm f/2.3 and 200mm f/3 Vivitar Series Ones become the equivalents of a 180mm f/2.3 (1/3 stop slower than f/2) and 300mm f/3 (1/6 stop slower than f/2.8), both at bargain prices. The 50mm f/2 Zeiss Makro-Planar becomes a 75mm equivalent, and is gorgeous: that’s what I used for the picture of the 23 lenses.
It is worth adding that I often carry a 200mm f/3 Vivitar Series 1 (on a Nikon F) to supplement my Voigtländers, because rangefinder cameras aren’t much good with lenses beyond about 90mm. This lens, long out of production, focuses to around 1/4 life size, or 1/2 life size with a tele-converter fitted. This is one reason why I use the 200mm f/3 more than my old Nikon 200mm f/4.
Roger W. Hicks/Shutterbug
One of these faster Vivitar lenses to have cult status now is the 200mm f/3 Series I lens. From Third Party Lenses Table, you can see that this lens sold for $334 in 1974, equivalent to $1,161 in today's 1998 inflated dollarettes. Half a stop slower 200mm lenses sold for a third as much, so this was a pricey lens!
Nearly as fast as a very expensive pro f/2.8 lens, this lens is relatively small (4.6 inches) and compact on the camera. You can hand-hold it nicely, although it is fairly heavy at 29 ounces. But the lens is very sharp and delivers superb results. The f/3 aperture is odd and slightly slower than an f/2.8, but hardly noticeably so even on slide film. Unlike many telephoto lenses, this 200mm will close focus to 4 feet, yielding a 1:4 reproduction ratio on film! Unlike many 200mm f/2.8 telephotos, it also uses smaller standard 72mm filters.
Robert Monaghan
Dzięki,spróbuję jakoś spożyć ten obcy język :-)
fotonyf napisał/a:
Smacznego.
Może jeszcze dodam, że szkło robione przez Komine, produkowane przez krótki czas od 1974 roku.
Vivitara 200 f/3,5 . możliwe by było aż tak ładnie ?
zdjęcia wykonane niby canonem 300d i Olympusem E-1
kudel  Dołączył: 11 Mar 2007
Re: Vivitar 200mm f/3.5
takpoprostu napisał/a:
Obrazek
Kupiłem go 1,5 roku temu na allegro, trochę się nim nawet pobawiłem. Bardzo fajne szkiełko, ale zaznaczam, że używalne od 5.6. W pełni otwarty mocno mydli, domknięty jest naprawdę ostry.
masz jeszcze jakieś fotki z niego ?
mam całkiem sporo, tylko że na innym kompie, w innym kraju:)
online dostępne jest tylko to
