Welti 1C, Zenith EM, Pentax ME S,K30, K100d super, Metz 50, M42 Heliosy, 28/3,5; 50/1.4 SMC Takumar, Sonnar, Vivitar, Pentax 28-90, 18-135 itp.
Bogdan napisał/a:Wszelkie programy z jakich korzystam, podają jedynie ogniskową, nie podają typu obiektywu.
Łukasz Bakuła
Bogdan napisał/a:Imagine podaje dane obiektywu z JPG-a?
Łukasz Bakuła
ExifTool Version Number : 10.23
File Name : pentax_k5_09.jpg
Directory : /home/bodzio/Downloads
File Size : 9.4 MB
File Modification Date/Time : 2016:08:15 20:03:10+02:00
File Access Date/Time : 2016:08:15 20:03:30+02:00
File Inode Change Date/Time : 2016:08:15 20:03:17+02:00
File Permissions : rw-r--r--
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Big-endian (Motorola, MM)
Make : PENTAX
Camera Model Name : PENTAX K-5
Orientation : Rotate 270 CW
X Resolution : 300
Y Resolution : 300
Resolution Unit : inches
Software : K-5 Ver 1.00
Modify Date : 2010:11:17 12:37:14
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/60
F Number : 4.5
Exposure Program : Aperture-priority AE
Exif Version : 0221
Date/Time Original : 2010:11:17 12:37:14
Create Date : 2010:11:17 12:37:14
Components Configuration : Y, Cb, Cr, -
Flash : Off, Did not fire
Focal Length : 24.4 mm
Pentax Version : 7.0.0.0
Pentax Model Type : 0
Preview Image Size : 640x480
Preview Image Length : 36080
Preview Image Start : 11572
Pentax Model ID : K-5
Date : 2010:11:17
Time : 12:37:14
Quality : Premium
Flash Mode : Off, Did not fire; Internal
Focus Mode : AF-S (Focus-priority)
AF Point Selected : Auto
ISO : 800
Exposure Compensation : 0
Metering Mode : Multi-segment
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Auto
DSP Firmware Version : 1.00.00.00
CPU Firmware Version : 1.00.00.00
Effective LV : 7.1
Image Editing : None
Picture Mode : Aperture Priority; 1/3 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Sensor Size : 24.122 x 15.976 mm
Data Scaling : 8192
Preview Image Borders : 28 28 0 0
Lens Type : smc PENTAX-DA 18-55mm F3.5-5.6 AL WR
Extender Status : Not attached
Sensitivity Adjust : 0
Image Edit Count : 0
Camera Temperature : 19 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0
Image Tone : Bright
SR Result : Stabilized
Shake Reduction : On (7)
SR Half Press Time : 2.23 s
SR Focal Length : 25 mm
Shutter Count : 9
Faces Detected : 0
Face Position : 0 0
Raw Development Process : 8 (K-5,K-5II,K-5IIs)
Hue : Normal
White Balance Auto Adjustment : On
Tungsten AWB : Subtle Correction
Dynamic Range Expansion : Off; 0; 0; 0
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : New York
Destination City : New York
High/Low Key Adj : 0
Contrast Highlight : 0
Contrast Shadow : 0
Contrast Highlight/Shadow Adj : Off
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Auto; Active (Weak)
AF Adjustment : 0
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : Off; 0 faces detected
Face Detect Frame Size : 0 0
Shadow Correction : Off
ISO Auto Parameters : Standard
Cross Process : Off
Distortion Correction : Off
Chromatic Aberration Correction : Off
Peripheral Illumination Corr : Off
Bleach Bypass Toning : Off
Black Point : 513 515 517 515
White Point : 14176 8192 8192 16960
Picture Mode 2 : Aperture Priority
Program Line : Normal
EV Steps : 1/3 EV Steps
E-Dial In Program : Tv or Av
Aperture Ring Use : Prohibited
Flash Options : Normal
Metering Mode 2 : Multi-segment
AF Point Mode : Auto
Focus Mode 2 : AF-S
AF Point Selected 2 : Auto
ISO Floor : 100
Drive Mode 2 : Single-frame
Exposure Bracket Step Size : 0.3
Bracket Shot Number : n/a
White Balance Set : Auto
Multiple Exposure Set : Off
Link AE To AF Point : Off
Sensitivity Steps : 1 EV Steps
ISO Auto : On
AE Exposure Time : 1/55
AE Aperture : 4.4
AE ISO : 800
AE Xv : 0
AEB Xv : 0
AE Min Exposure Time : 1/7723
AE Program Mode : Av, B or X
AE Aperture Steps : 3
AE Max Aperture : 4.0
AE Max Aperture 2 : 3.8
AE Min Aperture : 27
AE Metering Mode : [0], [1]
Flash Exposure Comp. Setting : 0
Level Indicator : 2
Min Focus Distance : 0.25-0.28 m
Focus Range Index : 7 (very far)
Lens Focal Length : 24.4 mm
Nominal Max Aperture : 4.0
Nominal Min Aperture : 27
Max Aperture : 3.7
AE Metering Segments : 7.6 7.5 6.9 5.2 5.1 5.1 5.4 5.6 5.6 6.0 5.9 7.6 7.8 6.9 5.0 5.0 5.2 5.5 5.4 5.6 6.1 6.0 7.2 7.4 6.6 5.1 5.5 5.2 5.2 5.2 5.5 6.1 6.2 7.1 7.2 6.9 5.1 6.0 5.8 4.2 4.2 4.2 4.5 5.1 7.4 6.9 6.6 5.5 5.5 5.6 5.6 5.8 5.6 6.2 6.0 7.4 7.0 6.4 5.4 5.1 5.5 5.5 5.6 5.8 6.1 5.9 6.9 7.4 6.5 6.2 6.2 5.6 5.5 5.9 5.9 6.1 6.1
Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Slave Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Manufacture Date : 2010:09:19
Production quote : 2.1
Internal Serial Number : 2864
Power Source : Body Battery
Body Battery State : Full
Body Battery Voltage 1 : 7.64 V
Body Battery Voltage 2 : 7.27 V
Body Battery Voltage 3 : 7.88 V
Body Battery Voltage 4 : 7.39 V
AF Predictor : -1
AF Defocus : 0
AF Integration Time : 30 ms
AF Points In Focus : Center (horizontal)
Kelvin WB Daylight : 5205 0 2.11572265625 1.45166015625
Kelvin WB 01 : 2500 0 1.156005859375 2.783447265625
Kelvin WB 02 : 2630 0 1.221923828125 2.6146240234375
Kelvin WB 03 : 2780 0 1.295166015625 2.4498291015625
Kelvin WB 04 : 2940 0 1.3702392578125 2.3021240234375
Kelvin WB 05 : 3130 0 1.4547119140625 2.15625
Kelvin WB 06 : 3330 0 1.5386962890625 2.02880859375
Kelvin WB 07 : 3570 0 1.6329345703125 1.9036865234375
Kelvin WB 08 : 3850 0 1.7342529296875 1.7855224609375
Kelvin WB 09 : 4170 0 1.8397216796875 1.6781005859375
Kelvin WB 10 : 4550 0 1.9520263671875 1.5775146484375
Kelvin WB 11 : 5000 0 2.06884765625 1.4854736328125
Kelvin WB 12 : 5560 0 2.193359375 1.3988037109375
Kelvin WB 13 : 6250 0 2.32080078125 1.319580078125
Kelvin WB 14 : 7140 0 2.4525146484375 1.2471923828125
Kelvin WB 15 : 8330 0 2.5863037109375 1.1807861328125
Kelvin WB 16 : 10000 0 2.719970703125 1.120849609375
WB Shift AB : 0
WB Shift GM : 0
Camera Orientation : Rotate 270 CW
Serial Number : 3825223
Source Directory Index : 0
Source File Index : 0
Level Orientation : Rotate 270 CW
Composition Adjust : Off
Roll Angle : -1
Pitch Angle : -9
Composition Adjust X : 0
Composition Adjust Y : 0
Composition Adjust Rotation : 0
WB RGGB Levels Daylight : 17485 8192 8192 12906
WB RGGB Levels Shade : 20892 8192 8192 9632
WB RGGB Levels Cloudy : 18840 8192 8192 11035
WB RGGB Levels Tungsten : 10508 8192 8192 23942
WB RGGB Levels Fluorescent D : 21590 8192 8192 12438
WB RGGB Levels Fluorescent N : 18512 8192 8192 13841
WB RGGB Levels Fluorescent W : 16829 8192 8192 17114
WB RGGB Levels Flash : 19825 8192 8192 11877
WB RGGB Levels Fluorescent L : 14079 8192 8192 21416
WB RGGB Levels User Selected : 17485 8192 8192 12906
Contrast Detect AF Area : 328 208 64 64
Sensor Temperature : 21.0 C
Sensor Temperature 2 : 21.0 C
Camera Temperature 4 : 21 C
Camera Temperature 5 : 21 C
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 4928
Exif Image Height : 3264
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Auto
Focal Length In 35mm Format : 36 mm
Scene Capture Type : Standard
Contrast : High
Saturation : Normal
Sharpness : Hard
Subject Distance Range : Distant
PrintIM Version : 0300
Compression : JPEG (old-style)
Thumbnail Offset : 54592
Thumbnail Length : 6619
Image Width : 4928
Image Height : 3264
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 4.5
Image Size : 4928x3264
Lens ID : smc PENTAX-DA 18-55mm F3.5-5.6 AL WR
Megapixels : 16.1
Preview Image : (Binary data 36080 bytes, use -b option to extract)
Scale Factor To 35 mm Equivalent: 1.5
Shutter Speed : 1/60
Thumbnail Image : (Binary data 6619 bytes, use -b option to extract)
Circle Of Confusion : 0.020 mm
Field Of View : 53.1 deg
Focal Length : 24.4 mm (35 mm equivalent: 36.0 mm)
Hyperfocal Distance : 6.49 m
Light Value : 7.2
Artur
Większość technicznych pojęć jest mi obca, ale nie przeszkadza w pstrykaniu ;)
Bogdan napisał/a:kwrom
Którą wersję irfanview posiadasz?
Bogdan napisał/a:Czyżby K-30 tak miał?
Najczęściej używane: K-1, K-3iii, 150-450, P24-70. Ulubiony K5iis. Sporo innych szpejów - spytaj.
K-30, MZ-50, ME, EX1. 29er.
https://barmiska.blogspot.com/
Pentax K-30, DA70_Ltd, DA50-200_WR, M50_F2, K135_F3.5, F70-210, S17-50_F2.8
