Markus  Dołączył: 21 Mar 2007
Nowe DCU 5.9.2
Zachęcam do pobierania.
www.ricoh-imaging.co.jp/e...ility5_win.html
[Additional items from previous Versions]
Corresponds to K-3 Mark III.
Corresponds to the folder tree display of MTP-connected cameras and easy image import
User-set filters can be set in the monotone of custom image setting.
The "Shake Reduction" item in the movie shooting information display now supports an "ON" indication to show that the sensor shift image stabilization has been used.
In the "Digital Filter History" dialog box in the shooting information display, the ±4 display of saturation, hue, contrast, sharpness, and shading intensity is now supported.
Display of “Highlight-weighted metering" is now supported in the "AE Metering" field of the shooting information display.
Added lens data.
[HD PENTAX-FA 43mmF1.9 Limited]
[HD PENTAX-FA 31mmF1.8 Limited]
[HD PENTAX-FA 77mmF1.8 Limited]
[Improve from previous Versions]
The color temperature setting of the white balance has been subdivided into 10K units.
The function to change the display magnification of the histogram has been added.
Brightness/R/G/B simultaneous display function of histogram is added.
The function to calculate the histogram with the pixels in the trimming area only has been added.
Display/hidden display setting for each item of shooting information display has been added.
Added "Show image in new tab" to the context menu of the image display area.
The "Align Image Left/Right" and "Align Image Top/Bottom" options have been added.
The method of specifying the copy source for spotting has been improved.
Improved the display of the origin of the parameter adjustment slider.
Added a tooltip when hovering the mouse cursor over the icon in the Custom Image panel.
Changed so that the highlight adjustment process is not performed when the check box for highlight adjustment is unchecked.
[Corrections from previous Versions]
Corrected --- When "Any" is selected for the aspect setting of the trimming frame, the default value of 1:1 is not correctly set for the default trimming frame.
Corrected --- Fixed the problem that the aspect ratio shifts when dragging the extension handle of the selection frame when the aspect ratio is set to "Any" in trimming the vertical image.
Corrected --- Fixed the problem where the vertical/horizontal position of the paper designation combo box and the vertical/horizontal position of the trimming frame are opposite in the "Fixed" trimming mode.
Corrected --- Fixed a problem in which the image could not be saved when trying to extract RAW with fringe correction turned on.
Corrected --- The thumbnails displayed on the transfer folder selection screen for easy image importing are not linked to the selected folder.
Corrected --- When moving the selection frame on the file list with the left and right cursor keys, the next step will not be available at the movie section.
Corrected --- The problem where the default image finish is set to "Natural" and the image quality does not return to the expected level even if "Reversal Film" is selected again when redeveloping JPEG images saved from RAW images taken with models such as the *ist DL with the image finish set to "Reversal Film" in DCU5.
Corrected --- A problem in which the image would turn magenta when redeveloping a JPEG image shot with the image finish "MUTED" on models such as the K-5II.
