Moje gnioty
K-5, DA SMC 15/20-40/70 LTD, DA*50-135/2.8, SMC A 50/1.7
| K100D Super - SMC DA 18-55 AL - UV HOYA HMC SUPER - PL-CIR HOYA HMC - O-ME53 |
Moje gnioty
"Przychodzi baba do pasmanterii..."
Awatar przedstawia buraka pastewnego.
K-5 i pare szkieł
CytatEach command will need a different SD card or to rewrite the MODSET file.
Main steps are
-1 Using a file to access the debug mode
-2 Using a file to show the list of commands and then save the original EEPROM
-3 Changing the EEPROM file with notepad++ or the Body it self
-4 Load the modified EEPROM inside the lens
-5 deseactivating the debug mode
The easiest is to use not updated K10D or K20D so you will easily access the debug mode by following pentax-hack instructions.
As I do not own a 50-135mm, I will only talk about the process using a 16-50mm DA* with my K10D.
Let's start after the battery fully charged and the 16-50mm mounted on it.
{{STEP 1}}
I only know the process to access debug mode with firmware 1.30 updated K10d.
So using Notepad, create a file nammed MODSET.TXT
inside, only write :
[DEBUG_MODE EN]
Put the file in the root of the SD cardPut the card inside the switched Off DSLR.
Press and Hold MENU button and switch on the DSLR.
If everything OK, it will be written :
DEBUG MODE
{{STEP 2}}
TAke back your SD card and change the file MODSET.TXT and write inside only
[OPEN_DEBUG_MENU]
If everything OK, it will show you all options avaible on Debug mode :
Beware to not change a thing you do not need ( once again, all this are made at your own risk)
Use the pad to go to the line
LENS EEPROM SAVE
Make a saved file of the EEPROM to allow you to reverse the process in cas of troubles
{{STEP 3}}
To modify the EEPROM, you can
-Either access the LENSEEP.LNS file you create by saving the file, I ask you to use Notepad++ Notepad++ Home
-Or go to the line :
LENS EEPROM READ/WRITE
You can change the quote line by line
Using NOTEPAD++ : DO NOT FORGET TO SAVE A FILE AND MODIFY A COPY FOR YOUR OWN SECURITY
Then change the quote "C0" by "80" in the colonn 03,for the following lines
-* 0020
-* 0060
-* 00A0
-* 00E0
-* 0120
-* 0160
-* 01A0
-* 01E0
-* 0220
-* 0260
-* 02A0
-* 02E0
-* 0320
-* 0360
-* 03A0
-* 03E0
Using the DSLR directly : DO NOT FORGET TO SAVE A FILE AND MODIFY A COPY FOR YOUR OWN SECURITY
Using the pad and dial, access the READ /WRITE function, check by read the info before modify it. Really check the info at the adress before change it. You need to read "C0" WRITE "80"
-* 0023
-* 0063
-* 00A3
-* 00E3
-* 0123
-* 0163
-* 01A3
-* 01E3
-* 0223
-* 0263
-* 02A3
-* 02E3
-* 0323
-* 0363
-* 03A3
-* 03E3
{{STEP 4}}
Put the modified fil LENSEEP.LNS in the root of the card and load it as using the Debug mod ( line under the line you use for saving the file )
LENS EPPROM LOAD
{{STEP 5}}
Check your lens on the DSLR, the SDM will no more work, Then take back your SD card and modify the MODSET.TXT file.
With this command
[DEBUG_MODE DIS]
If everything OK, you did it, the DSLR will work as before, and the 16-50mm will not use SDM on any DSLR unlast you relaod the old LENSEEP.LNS.
K10D + Tamron 17-50mm F2.8 IF + Sigma 105mm f2.8 EX DG Macro + Pentax 18-55 3,5-5,6 AL + Metz 48 AF-1
www.morawiec.info Fotografia Zbliżeniowa
K-5 i pare szkieł
Moje gnioty
Trzeba będzie zapisać ten opis na dysku na wypadek zniknięcia z internetu.pawcio napisał/a:Znalazłem jeszcze opis "naprawy" silniczka
http://bangmedia.no/pentax/sdmfix/
Taka naprawa jak opisana jest baardzo prosta. Nie wiem skąd jesteś ale jak się bardzo boisz to ewentualnie mogę pomóc.pawcio napisał/a:AF mi nie działa w 16-50 i zastanawiam się nad taką "naprawą".
Chociaż trochę strach te śrubki takie malutkie ;)
K-3 | K-30 | DA* 300mm f4 | DA 35mm f2.4 | M 28mm f2.8 | M 50mm f2 | Takumar 50mm f4 | DA AF 1.4X AW |
K-1 | D FA 24-70/2.8 | FA 43/1.9 | FA 77/1.8 | F 24-50/4 | F50/1,4
PRACTICE MAKES PERFECT!
